TwinTurbo.NET: Nissan 300ZX forum - The steering shaft spline needs to be put back in at a
Subject The steering shaft spline needs to be put back in at a
Posted by doug8867 on July 02, 2008 at 9:24 PM
  This message has been viewed 836 times.
In Reply To Steering ~20 degress off center to the left posted by Tikki on July 02, 2008 at 09:04 PM
Message different spot at the joint underneath the car. The "offset" typically happens
when someone has forgotten to mark the spline before removing it, say
when installing steering rack bushings, and then puts it back in a spot that
is different.
Not really hard, but does take some trial and error to find the right spot.
Make sure you mark the spline before you remove it, so you can rotate it
a few spots on the spline and then replace it. You won't know if you've got
it in the right spot until you take it for a test drive.
Try searching "replace steering rack bushings" for more info on the shaft
and spline.
